Need tin sheets approx 28 ga
I NEED THESE IN DIFFERENT SIZES BUT MUST BE ABLE TO SHIP UPS SIZES.
HANNAH WILLIAMSDesigner - DRY BRANCH, GEORGIA, USA
August 20, 2011
Hi, Hannah.
Tin is an element and a metal, and sheets of tin are available. However, people have confused the issue a bit with slang, referring to sheet metal as "tin". Just so people aren't wasting your time, are you sure that you need sheets of tin, not of cold rolled steel or galvanized steel sheet metal?
August 22, 2011
