Can my Yamaha's cracked titanium pipe be gas welded?
I have a Yamaha yz 450f. My header has a crack in it. it is titanium. Can this pipe be gas welded?
Kevin Smithmotorcycles - Dayton, Nevada, USA
August 19, 2011
Tig welding must be OK.Hope it helps and good luck!
First of two simultaneous responses -- August 23, 2011
Don't know what you mean by gas welding. Titanium is generally GTAW (TIG argon) welded. G. Marrufo
Second of two simultaneous responses -- August 23, 2011
Titanium is usually welded with Tig process. Special precautions are used above normal for TIG. Inside may have to be purged with argon. Outside may have to use a trailing gas nozzle or you may have to weld it in a sealed and purged "glove box" . Also sensitive to overheating I understand.
Tim
- Orlando, Florida, USA
November 1, 2011
