E-coating a carbon steel candle holder for outdoor use
August 17, 2011
Hello sir,
I am now developing a item, which is a cast candle holder, material is carbon steel 35#, it will be used in outdoor environment. For a good looking surface, we decided to choose E-coating for surface treatment. Color is Black matte.
My question is what kind of test is required for the corrosion resistant? Neutral salt spray 5%? How many hours would be enough?
Thank you. I'm looking forward to your reply.
Andy Zhang
quality engineer - Fujian, China
Hi, Andy.
Salt spray hours are not indicative of real life, and by asking for salt spray hours I think you may be doing the design of the finish a little backwards.
For outdoor exposure, start by choosing a robust finishing process. E-coat alone, even after a good zinc phosphate pretreatment, is probably not enough. I think you need to add a layer, either zinc plating under the e-coating or a polyurethane topcoat or a powder coating over the e-coating.
August 18, 2011
Ted is 100% correct. When the UK had a car mf industry, most under-body parts were expected to conform to specs calling for very high physical and chemical performance (1000 hrs ASTM B117). This was achieved by using zinc phos followed by a coat of polyester semi matt black, 18-20 gloss. Belt and bracers used by some coater's included a e-coat as a primer.
Terry Hickling
Birmingham, United Kingdom
August 22, 2011
