Zinc roofing questions
A homeowner building a ranch guest house in NE Oklahoma, I love the look of zinc roofing. It used to be mined here but I don't see any zinc roofs. Is this exceedingly green metal used much for roofing in the US? Need zinc coil roofing, about 3,000 sq. ft., standing seam or panels
Lee Kottke
homeowner - rural Lenapah, Oklahoma
July 30, 2011
It is available. Check with several roofing material stores for prices. It will vary quite a bit depending on metal thickness, galvanizing thickness and which type of standing seam you plan to use.
