Attempting to artistically corrode metal
June 8, 2011
I have had some experience working with muriatic acid; however, by itself it's not really giving me the look I'm going for. I have a couple of pictures that might detail better what I'm looking to do. I know the guys who took this picture are using several chemicals to get their final look.
I was hoping you could maybe take a look and give me some direction. Thanks
Matthew AnthonyCustom rat rod builder - Morganton, North Carolina USA
Try 5% iron (III) chloride solution. Salty water can be used too. Object must be well degreased. Hope it helps and good luck!
June 15, 2011
Use table salt and hydrogen peroxide. For more brown and less orange you can add a bit of copper sulphate ⇦ this on eBay or Amazon [affil links] to the mix.
Justin Kumpfmanufacturing - Philadelphia, Pennsylvania, USA
June 21, 2011
