Aluminum electroplating on steel
I having a final year project in my school and in my project I would like to use aluminum coat on steel by electroplating.But I have no idea what electrolyte I should use in my experiment. So far what I know is only ionic liquid can have a good plating. Is there any other electrolyte can be use for electroplating?
Ng Kok Jun
Student - Malaysia
June 10, 2011
S
I
M
U
L
T
A
N
E
O
U
S
R
E
S
P
O
N
S
E
S
The only process I know of is a proprietary patented process from Alumiplate. They plate aluminum from an organic solvent bath. If you don't do it correctly there is certainly potential for an explosion. I personally think that you would be better off picking a different project.
Jon Barrows
Jon Barrows, MSF, EHSSC
Independence, Missouri
June 10, 2011
You cannot electroplate aluminum from an aqueous solution. There is a company in the US who does aluminum electroplating using a proprietary solvent solution in an inert atmosphere. I have a hunch that this would be too expensive for your project; I'd try to replace the aluminum with something else.
James Totter
James Totter, CEF
- Tallahassee, Florida
June 13, 2011
