Thread 572/80
Galvanneal surface rust
Had some galvanneal steel doors stored outside in the elements for about a year and they develop a reddish-brown discoloration (rust) on the surface. What do I need to do before painting? Do I have to have it re-galvlnized/annealed after removal of rust with wire brushing or could I just paint over it?
R.C
engineer - Hartsdale, New York, USA
June 8, 2011
publicly reply to Roger Cooper
June 8, 2011
Galvanneal is a very thin zinc coating, not suitable for rust prevention in an outdoor situation. It did OK to last that long.
If you needed exterior protection, then hot dip galvanizing might have been suitable.
Now that you've got rusty doors, you need to get the rust off and put some protection on there.
Wire brushing rarely gets it all off, but shotblasting does.
When its clean get some zinc on there somehow. Could be a zinc rich paint, zinc rich powdercoating, or if the substrate is suitable then Hot Dip galv (in the latter's case the shot blasting will not be required as the HDG process deals with rust like this).
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
publicly reply to Geoff Crowley
August 1, 2011
Your job seems to a thin Galvanized sheets which is corroded / white rust.
There are many reputed brands of Zinc Ritch paints (Cold Galvanizing) are available in market.
To use it clean the surface and apply the paint. After drying you can use your own colour paint. It will work as good as Galvanized.
- Mumbai, Maharashtra, India
publicly reply to Umesh Dalela
