Drying temperature after electrodeposition?
Hi
This is Abdul Baseer Siddiqui, I am serving as Deputy Manager Process Auditing. Drying temperature after electrodeposition?
Process Auditing - Karachi, Pakistan
May 21, 2011
No "flash card" quizzes, please, cousin Abdul. No one can help you that way. By electrodeposition, I assume that you mean electroplating of a metal coating rather than of an electrophoretic lacquer?
The temperature is not critical for most plating processes, although the work should not exceed 140° F if it has been chromate conversion coated. What is usually more important, since we generally want bright spot-free work, is that the dryer strip most of the water off of the parts rather than baking away the water and leaving its dissolved salt on the components.
If you can tell us about the parts, what kind of plating they have, and whether the work is rack plated or barrel plated, we may be able to help further. Good luck.
May 26, 2011
July 30, 2011
Sorry!
Actually my question was "What is the recommended temperature for baking after Zinc electroplating + chromate"???
Our process flow given below:
Part: Shaft assembly
055mm
Length: 70mm
"The requirement of locking agent which we are using for assembly must be cured at 60 °C but majority of parts getting fail in SST but individual parts are okay"
Ultimate question is overheating can be a reason for SST failure????
- Karachi, Pakistan
