Pin holes when spraying semi gloss latex
Q. What would cause pin holes when spraying hvlp with latex semi gloss?
SCENIC ARTIST - LOS ANGELES, CALIFORNIA, USA
May 20, 2011
A. You probably have some contamination on the surface of the substrate causing surface tension issues with the coating.
Ronald ZeemanCoil Coating - Brampton, Ontario, Canada
May 25, 2011
