Flux for alumina rich hot-dip galvanizing
We are wondering whether the hot-dip galvanizing in a 5%Al and 95%Zn dip by single-dip would require special flux, as sometimes mentioned in the literature.
Norbert Rudolf Dr. Ing. Seyfert
product designer - Olpe, Germany
May 19, 2011
May 19, 2011
Sir:
Any zinc bath over about 0.007% aluminum requires a special flux.
I have read a patent on a special flux for higher aluminum containing zinc baths. I do not wish to be accused of encouraging others to violate a patent so I am not able to give you a reference. Also I do not wish to comment on this flux for the same reason.
I think there are two ongoing researches, one with around 0.04% aluminum and the other as you have indicated 5% aluminum. Both pose interesting positive and negative likely results. White rust may be a problem and floating aluminum/iron rich dross may be a second problem.
I have gone a different direction and I am writing an article titled "Lead-Free Hot Dip Galvanizing."
Dr. Thomas H. Cook
