Hobbyists & Industry luminaries alike learn on every visit
(we earn from 'affiliate link' purchases)
Tin Plating stains on Copper
April 22, 2011
I am applying plating on Brass and Nickel however some stains appear after tin plating is done. Stain looks like the foam bubbles are attached to the parts plated, leaving very visible white circle stains.
Can you help me with this?
Sergio Samaniego
Mexicali, Baja California, Mexico
That is the typical stain from the tin solution surfactant not rinsing off. You have to go into an alkali and then rinse again. Most vendors have a special product for removing this tenacious film. Try a non-etch mild alkaline cleaner, or just 4 oz/gal sodium carbonate this on eBay or Amazon] , then rinse again.
robert probert
probertbanner
First of three simultaneous responses -- April 25, 2011
Second of three simultaneous responses -- April 25, 2011
Hello,
Is there a possibility you may have a previous surface or plating that is already porous? In any case you may want to inspect the surface right before entering the tin bath with a magnifying glass. If the surface is free of pores you may need to purify your solution and check with your chemical vendor what surfactant is compatible with their chemistry and its optimum concentration. If you find previous porosity, you need to identify the origin. Good luck,
G. Marrufo-Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
Third of three simultaneous responses -- April 26, 2011
1. Do not plate tin directly on brass. You need a copper or better a nickel layer in between.
2. After rinsing the parts following the tin plating, dip in a slightly alkaline solution, then rinse again
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
