Cannot clean copper roses
Hello, my name is Brenda. I am an artist who makes roses out of copper... The problem I am running into is the discoloration caused by using a torch to braze the petals onto the stem. I cannot seem to get the oxidization off enough to patina the rose, I would rather not use any real caustic chemicals, and my Dremel this on eBay or Amazon [affil links] only goes so far in cleaning them due to the arrangement of the petals. Can any body give me some ideas? Thank you so much.
57056
Brenda Westberg
artist - Portland, Oregon, USA
April 17, 2011
Try hot solution (80° C) of 47,5 gms citric acid this on eBay or Amazon [affil links] /47,5 gms sodium gluconate/5 gms tartaric acid this on eBay or Amazon [affil links] /1-5 lit water.Hope it helps and good luck. vinegar in bulk on eBay or Amazon [affil links] and peroxide mix can be used too. Hope it helps and good luck.
Very good article on peroxide based pickling solutions for jewelers - users.lmi.net/~drewid/PWR_Pickles.html
Hope it helps and good luck!
