One anodizer can make shiny parts, one can't
April 18, 2011
We've got an anodizing mystery -- two anodizers, one makes beautiful, clear, shiny parts, the other's parts are dull and lifeless looking.
Both get the same stock 6063-T4 extrusion, they are both plating to the same spec (MIL-A-8625F Type II Class 1, 12-16 µm thick).
I've included 1000X pictures of the dull surface and the shiny; hopefully this will look familiar to someone and we'll be able to provide feedback to the misbehaving vendor.
Engineer - Fremont, California, USA
Roger
I would suspect the pretreatments are different. You could ask both suppliers to pull a part off the rack immediately prior to anodize and examine.
- Colorado Springs, Colorado
First of two simultaneous responses -- April 19, 2011
Two different shops can "meet" the Mil Spec but have different (1) free acid and/or (2) different temperature, and/or (3) different current density, (4)etch differences (this is probably yours judging by the lines in the pictures,) and several other factors. If cosmetics is an issue, the supplier should be furnished a sample finish to "shoot for" and be sure to tell him the tolerances on the machine parts.
Second of two simultaneous responses -- April 19, 2011
