Sodium Cyanide wrongly added to Potassium Cyanide based Silver Plating Solution
April 7, 2011
A plater by mistake has added 10 kg (22.4lb)of sodium cyanide instead of KCN to a potassium cyanide based silver plating solution. The operating limit of free KCN is
8 - 12 oz.wt/gal.
What will be the effect on the plating deposit quality, if used as it is and the KCN addition done in the future?
Plating Shop Senior Supervisor - Abu Dhabi, UAE
You will not notice any problem
April 10, 2011
No harm done.
There are platers who use a combination of potassium and sodium cyanide for silver plating.
Sara Michaeli
Tel-Aviv-Yafo, Israel
Shouldn't be any problem
