Electrogalvanize
From time to time we see a spec for electrogalvanize. Is this the same as electrozinc? If not, what is the difference?
Bruce Miller- Sycamore, Illinois
Yes, electrogalvanize is the same as electroplated zinc. The term is most commonly used to refer to zinc plating of steel strip on a continuous strip plating line.
David J. SuggWorthington Steel - Malvern, Pennsylvania
