Filter cake is hex chrome not trivalent
we are a materials recovery firm that handles ni/cr ECM filter cake for a client (65% water, 10%salts, 25% metal containing solids by weight. We would like to dry the material to reduce bulk and dead weight freight (water). but the chrome fraction presents as hex chrome. is their an effective/practical way to convert hex cr to tri cr? Thanks for your help.
Robert Raizkbusiness owner - Wilmington Ohio U.S.
March 24, 2011
You might try combining the wet cake with ferrous sulfate ⇦ this on eBay or Amazon [affil links] , allowing it to stand for a few hours, and then drying.
Dave Wichern
March 28, 2011
Dave, thanks for your response. Any idea how much ferrous sulfate ⇦ this on eBay or Amazon [affil links] per ton? Source, cost of ferrous sulfate ⇦ this on eBay or Amazon [affil links] ? Thanks.
Robert Raizk- Wilmington, Ohio, USA
April 7, 2011
Unfortunately, it takes a large amount of ferrous sulfate
⇦ this on
Amazon [affil links] compared to hexavalent chromium, and a long, long time at neutral or alkaline pH for ferrous sulfate
⇦ this on
Amazon [affil links] to work.
The best solution may be to work with the generator to have them reduce the hex chromium to trivalent before flter pressing. This is usually done with sodium metabisulfite at a pH below 3. Another possibility is to use alkaline sodium sulfide or an organic sulfide at neutral pH. This assumes that a sulfide containing sludge is compatible with your recovery process.
April 8, 2011
sodium hydrosulfite
⇦ this on
Amazon zincaffil links] will reduce hexavalent chromium in alkaline conditions.
If considering use take care as the powder is spontaneously combustible in moist conditions.
Geoffrey Whitelaw
- Port Melbourne, Australia
April 11, 2011
Mr. Kirman is right, though I think that limiting factor is the solubility of the ferrous ion at the likely pH of the filter cake, rather than the speed of the reduction. Fe2+ will precipitate, and unless some kind of machinery is used to grind the ferrous sulfate
⇦ this on
Amazon [affil links] together with the sludge, intimately, the reaction will not proceed to completion.
If this equipment is available, I still think ferrous sulfate
⇦ this on
Amazon [affil links] is worth a try.
Geoff beat me to it, suggesting NaS2O4 as a reductant that works at high pH levels. His caveat regarding its spontaneous flammability is important and is to be heeded. I would apply it as a saturated solution to the solid filter cake, then mix very well, then dry. Though I do not know, I doubt that the sludge/dithonite mixture will burst into flame. A well designed lab test to confirm this is essential.
Dave Wichern
April 12, 2011
