Acidity in activator bath for electroless nickel plating
I am an engineer from a PCB shop in China; I have encountered a problem of controlling the acidity of the activator bath for EN plating.
We are using Pd catalyst and the recommended range is 80 - 200 ml/L, but now we have raise to ~270 ml/L and looks like it will require a further raise.
There are 2 sources of acid:
1. from Pd replenish during normal operation, acidity of this is 1200 ml/L.
2. drag-in from acid pre-dip, acidity of pre-dip 1000 ml/L
PCB shop engineer - Suzhou, China
March 16, 2011
I think you need to clarify your post, since a concentration of 1200 ml/L is impossible in normal usage. ![]() James Totter, CEF - Tallahassee, Florida Hi Kenneth, ![]() David Shiu - Singapore |
