Cleaning stainless steel with minor pittings for storage
Q. Hello to all,
I have been researching this site for a long time to find some guide (perhaps even a solution) to my problem. This may sound trivial but I have a small collection of some expensive discontinued stainless steel watches from the 1960's which have some pitting? to areas that cannot be machined out. They appear to be like very fine fly droppings and on one item like a small speck of fiber from a tissue paper. I know that whatever cleaning method used, these lesions will not go away unless machined but I am more concerned about stopping them from getting worse or spreading, as I know from literature that they do burrow through if left untreated. I want to clean these items to store away as they are collectibles, but am concerned that the pits will get worse if the pits still contain contaminants. Much of my research has suggested nitric acid, citric acid on eBay or Amazon [affil link] , baking powder, white vinegar ⇦ in bulk on eBay or Amazon [affil link] , electropolishing and many other debatable methods. As the stainless steel used is likely to be 304L grade or from the 300 series, I was informed that applying to these sections a cotton bud (to leave for approx. 30 minutes) of some Stop Rust ( consisting of 30% phosphoric acid and TRI-chromate - whatever this means) which is used on ordinary iron should be safe provided that it is then rinsed with demineralised water. I was also advised on a product Autosol stainless steel polish on eBay or Amazon [affil link] which consists of aliphatic and aromatic hydrocarbons. I am no expert on metals or finishing? I would be happy to receive some feedback, with many thanks,
Charles Dale
collector of stainless steel watches - Australia
A. Try 47,5 gms citric acid /47,5 gms sodium gluconate/4,9 gms tartaric acid on eBay or Amazon [affil link] / 1-10 lit water solution. Can be used hot or cold (according to expired USA patent USPT 4,264,418). Hope it helps and good luck!
