Solutions to Problems plating near to holes
When I try to plate near a hole for example a 1/2" hole I have to cover it because if I don't do this the nickel will be very thin and also the chromium will be difficult to plate.
why this happens, what is the reason for this, is there any alternative solution to this?
Daniel Hernandez
plating shop employee - Bucaramanga Santander Colombia
February 27, 2011
