Does white vinegar corrode all coins the same way?
does white vinegar in bulk on eBay or Amazon [affil links] corrode pennies, nickels, dimes, and quarters in the same way? I know that vinegar does remove rust and stuff from pennies, and also defaces it a little in the process, but does it do the same with the other 3 basic coins? (I'm in 7th grade)
Kara N [surname deleted for privacy by Editor]
Student - St. Pete, Florida
February 14, 2011
Hi, Kara.
Get four small glass or plastic bowls. Put a couple of ounces of vinegar in each. Put a penny in one, a nickel in another, a dime in another, a quarter in another. Then come back in a week, describe what you see, and ask us again. Good luck.
February 18, 2011
Another problem. Some, maybe all current coins are sandwich metals, which will react far differently than the older 1 metal alloy coins.
