Rhodium plating deposition per amp-hour
dear sir,
we are doing white& black rhodium plating [adv: black rhodium plating solution on eBay or Amazon [affil links] on our jewelry products. We want to know the rate of deposition per ampere hour of rhodium. We are using acid base proprietary chemical in our process. Please help us in this matter, we shall be thankful to you.
thanks
regards
Mahesh Aggrawal
employee in jewelry company - Jaipur Rajasthan India
February 18, 2011
Hi, Mahesh
There is a simple relationship for this called Faraday's Law of Electrolysis. At 100 percent efficiency, one coulomb (96,485 ampere-seconds) will deposit one gram equivalent weight of metal. Look up the molecular weight of Rhodium in the periodic table, divide by its oxidation state as an aqueous salt (+3), and you have how many grams will be deposited by a Faraday assuming 100% efficiency. Check with your supplier for the usual efficiency of their bath.
February 18, 2011
