Repainting peeling aluminum patio roof
I HAVE AN OUTSIDE PATIO ALUM. ROOF THAT WAS PAINTED WITH LATEX PAINT ABOUT 5 YEARS AGO. IT IS NOW PEELING AS I DID NOT PREP IT WELL I GUESS. I REMOVED THE PEELING WITH A WIRE BRUSH AND NOW I WANT TO PAINT IT IN HIGH GLOSS PAINT. I AM TOLD TO USE HOUSEHOLD vinegar in bulk on eBay or Amazon [affil links] AND WASH IT AND THAT WOULD PREP IT! BEING OLDER I WANT TO DO THE EASIEST WAY I CAN AND REDO IT MYSELF. WILL THIS WORK AND HOW DO I APPLY THE vinegar AND DO I HAVE TO RINSE IT OFF AFTER? PLEASE HELP ME. THANK YOU SO MUCH.
Angie Grooten
homeowner - Rockledge, Florida
February 16, 2011
Hi, Angie. vinegar is fine and you can dilute it 3 or 4 to 1 and, apply with a this on eBay or Amazon [affil links] , then simply rinse it off. But if you are looking for the easiest way, skip the vinegar and just use a self-etching primer before your high gloss paint.
February 16, 2011
