Cutting up solid Zinc Dross
During rebuilding of our zinc pot, I have ended up with a solid piece to dross 48" wide x 180" long with thickness of 4" to 8". What is the best/safest way to cut this into manageable pieces? I have tried a cement breaking jack hammer mounted to a bobcat but after 4 hours I did did nothing but make small grooves in one piece.
William Juhasz
Purchasing Manager - Niles, Michigan, USA
February 9, 2011
If the kettle (pot) is also scrap, then a thermic lance is very quick. You loose the volume that the cut occupies to fume (of which take adequate precautions).
If the kettle is to be preserved, then a shallow cut with a metal cutting blade (perhaps 2" deep) followed by jackhammer work.
Once you can get under one end, it gets easier to break.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
February 10, 2011
Thanks Geoff. We will try the thermal lance.
William Juhasz
February 14, 2011
