Spec'ing the Nickel plating on an aluminum heat sink
I need a simple note to put on a drawing to indicate I want bright nickel plating. I need to mention the MilSpecs in the note. QQ-N-290 .0004 thickness is required but what needs to be indicated as far as zincating and copper thicknesses? thanks
Anthony Klammproduct designer - Amityville, New York, USA
February 9, 2011
