TDS is lower then Total hardness
Is it possible, the total Hardness is higher then Total Dissolve Solids (TDS) of the same water.
Anwar Hossain
- Dhaka, Bangladesh
February 2, 2011
Hi, Anwar. If the two parameters use the same units I can't see how that is possible. Please put your question into context. If this a question on a homework assignment? Is a lab reporting such results? Thanks.
February 2, 2011
It is not possible. However, if you are measuring the TDS with a TDS meter, the reading is probably incorrect because it actually measures conductivity, not TDS. The most accurate way to measure TDS is to evaporate a filtered sample to dryness and to weigh the residue.
Lyle Kirman
February 3, 2011
If the hardness is being reported in mg/l CaCO3, but is present as magnesium, the results you describe are possible.
dave wichern
Dave Wichern
February 13, 2011
