Thread 566/17
Measurement of Zinc Coating Thickness on Wire Type Item
Dear Sir / Mdm,
Good day. I am from a galvanizing factory. I would like to ask what is the proper method to measure zinc coating thickness on wire / mesh (typically 2 mm diameter). I'm considering the use of caliper to measure thickness before and after, but it will not take into account the iron loss in pickling. The use of coating thickness gauge give me outrageous readings.
Galvanizing Plant - Employee - Selangor, Malaysia
January 30, 2011
publicly reply to CS Leong
