Protection for piece with Steel and Aluminum
Hello,
I am part of a Formula SAE team, it is a student built racing car project. All critical aluminum parts on the car are black anodized.
We have an existing part in 2024-T3 aluminum part that we wish to reuse and have finish to obtain a black color and basic corrosion resistance like the anodized ones. The problem is that there is Cadmium plated steel studs pressed in the part which we cannot remove.
I am worried that anodizing will attack the steel studs. We might have access to Epoxy E-coating but I am unsure about what will happen to the studs plating in the pre-treatment process.
Have someone experienced finishing similar aluminum/steel assembly? What are the option available for such an assembly?
Thank you!
Engineering student - Sherbrooke, QC, Canada
January 27, 2011
