Looking for a process to etch Zerodur - glass ceramic
I am looking for a process to etch Zerodur - glass ceramic.
Until now I etched the Zerodur 'M' by Ammonium bi Fluoride and got smooth surface and full transparency.
Now I tried to etch the Zerodur 'S' by the Ammonium bi Fluoride but I lost the transparency and the smooth surface - actually the Zerodur 'S' block I etched is opaque.
I tried to change the etching parameters time, concentration and temperature but I did not succeed to get the transparency and the surface quality I had before on the Zeodur 'M'.
Do you have any idea what to do ?
product designer - Israel
January 17, 2011
It would appear that there was more regular glass in the second material vs a higher amount of ceramic in the first. The fluoride went after any available silicon.
Don't use the second material.
I have to work with the Zerodur 's' so I have to find an etching process for this type.
Moshe- Israel
January 20, 2011
