Troubleshooting electrolytic plating rectifier fluctuations
January 13, 2011
Hello,
I'm Joel Bagaslao from a captive plating shop. I just wanted to know if there is any instrument that can detect the abnormality of the rectifier flactuation. My involvement I had 32 sets of Single plating rectifiers to maintain for electrolytic plating such as (Pure Tin/Nickel and copper plating.
I have no idea yet for the common problem may be encounter in the future. I'm an Equipment Technician on this plating line.
Bagaslao Joel
Equipment Technician - Lipa City, Philippines
Hi, Joel.
An oscilloscope meter can display those fluctuations, but a simpler and less expensive device called a "ripple meter" can more simply tell you if the rectifiers are limiting the fluctuations to within spec. Good luck.
January , 2011
