Chrome plating on ABS
January 11, 2011
We need chrome plating on ABS part which will be used as a handle in S.S vessel. Can you help us about Plating thickness and testing methods for chrome plating parts?
ABS Material grade - Absolac EP200
We were advised to have 10-15 microns thickness by the supplier. Sweat test and Grid line test on parts. Is it correct? Thanks.
Senthil Kumar
Designer - India
