How to get Pitted Black iron texture
Hi I need to create a heavily pitted effect on black iron pipe for a display. I know how to create rust but not so certain on how to create the heavy pitting texture. Any ideas?
56471
Kevin Smith
creative carpenter - Brooklyn, New York, USA
January 7, 2011
Chemical etching or texturing will produce any grain you want up to 1/64" deep or more.
G. Marrufo
Guillermo Marrufo
Monterrey, NL, Mexico
January 12, 2011
Any Recipes for texturing or pitting of the Black Iron?
Kevin Smith
- NY, NY, USA
January 14, 2011
It is not a simple straight forward procedure nor a recipe, you will need to get acquainted with the art of engraving with chemicals (acid etching). A brief googling will render thousands of valuable pages. Good luck
G. Marrufo
Guillermo Marrufo
First of two simultaneous responses -- January 17, 2011
Diluted hydrochloric acid must be ok,salty water probably too.Connect object to positive pole and piece of iron sheet to negative,current density depends on size of object.
Hope it helps and good luck!
Second of two simultaneous responses -- January 18, 2011
If you are going to venture into acid etching on your own, I would advise you to try it on some scrap pieces first before you try it on your workpiece.
Jim Schwartzmyer
- North Tonawanda, New York, USA
January 18, 2011
