Step test for duplex satin nickel
is there any specifications for step test for satin nickel plating?
Vijay Potdar
plating shop employee - Pune, Maharashtra, India
December 23, 2010
February 2, 2011
Dear Friend,
First what type of job you are plating the step test standard depend upon the part, because of if your plated part are plastic or metal plating in stain that time the std. of step test as per your customers req. so you got this std. from suppliers. and see.
In Satin nickel Plating - Two wheeler part step std. is 80 to 120 mv. step.
Sanjay Bawale
- Aurangabad, Maharastra, India
