Hydrofluoric / Nitric acid solution for pickling PH 15-7 Mo stainless steel
Q. Hello fellows,
I am facing a problem of black staining on A286 (precipitation hardening) stainless steel after pickling. Pickling is being performed in mix acid of HF and HNO3 followed by rinsing and warm water splashing. But the black spots or stains appear on the surface. Does anybody have seen the same problem or any suggestion?
Kind Regards,
Ridwaan
- Karachi, Pakistan
April 13, 2021
A. Hello Radwaan, I have seen this issue before when pickling different materials and traced it back to work hardened area that happened during the machining process but wouldn't show up until after pickling because work hardened area doesn't etch the same and generally turns black from my experience.
Mark Battles
Plymouth, Minnesota
April 23, 2021
I need a pickling bath consisting of hydrofluoric acid and Nitric acid for PH 15-7 Mo steel. Do any of you have any experience with this solution for etching steel? I have done some experiments with the solution but have some problems with Intergranular Attack in my samples.
Hope you can help, Thanks
Engineer, Chemical - Grenaa, Denmark
December 17, 2010
The first question is why are you pickling this part? - Navarre, Florida December 22, 2010 December 22, 2010 A. Tommy, Aerospace - Yeovil, Somerset, UK |
A. Once you sort out what Brian said, remember that you will need to titrate for free fluoride. It is not terrible, but it takes a bit of learning and can be frustrating.
James Watts- Navarre, Florida
December 23, 2010
January 4, 2011
Q. Hi Brian,
Here are the answers to your questions:
- The concentration limits are not certain but the experiments I have made were done at a 1:10 ration for HF:HNO3 %vol. So I have tried different concentrations at this ratio.
- Pretreatment of the samples are cleaning in a Turco soap to insure that the samples are clean. A water break test is made to insure the test pieces are clean.
- The amount of material to be removed are 10 um
- The immersion time is being determined by an etch rate test of the bath.
- The etch is done as to prepare the parts for penetrant inspection.
Thanks for the responses.
Maintaining acid levels in Nitric-hydrofluoric pickling process
Q. We pickle 304 stainless in a solution that is Nitric and HF. Our targets are 15%-20% Nitric and 1%-8% HF.
We are looking to get control of the acid levels by type so that we can establish more consistent dunk times and plan more effectively. We currently measure and use Baumé to determine where the acid level is. From there we make additions of Ammonium Bifluoride and Nitric. The method for choosing how much is essentially undefined.
I am looking for a better measurement method and a scientifically grounded process for maintaining the acid levels.
- Seattle, Washington
April 5, 2019
