Problem rinsing silicated cleaners
The advise is always to use a silicated cleaner you must rinse well due to the gelatinous film formed with the acids.
I don't have an ultrasonic cleaner, so it would help to use fluorides in acid dips to remove silicates?
Daniel Hernandez
Plating shop - Bucaramanga Santander Colombia
December 5, 2010
December 10, 2010
Daniel,
Are you talking about silicated soak cleaners, such as those produced by the likes of Chemetall, Atotech and MacDermid?
If you are then a good rinse for 2-3 minutes in cold, running, agitated water should suffice. If there is a contamination on the surface after rinsing a dilute acid rinse with either nitric acid or sulfuric acid should suffice to neutralise.
I would avoid using HF if I was you, that is a nasty acid to play with and I really don't think it'll do you any favours to be quite honest.
Brian Terry
Silicated cleaners are a serious pain if you do not get them into a rinse tank quite rapidly after coming out of the tank. The hotter the tank is, the faster you need to move it. I have seen dried on cleaner where we had to grit blast the surface.
Silicates are insoluble in neutral and acids. If the first rinse after using a silicated cleaner is neutral or acid, silicates precipitate as an insoluble film that is very difficult to remove. I suggest that the first rinse after alkaline silicated cleaners be at at pH 8 or higher. The silicates can then easily removed. Then transfer to a clean rinse and proceed from therein to acid treatments required for the metal substrate.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
           and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
December 29, 2010
