What is Tinsteel, what is Copper Flashing?
December 2, 2010
What is Tinsteel?
Does it mean steel which is electroplated with Tin?
If so what will be the base material?
Can I use CRCA or SS?
What's the difference for both?
Is the plating thickness same for both base materials?
Whats is meant by Copper Flashing?
how can we do that?
Why is it required in electroplating with Nickel?
Where are the applications?
GOPI KRISHNAN
PRODUCT DESIGN ENGINEER/MECHANICAL ENGINEER - ERNAKULAM, KERALA, INDIA
Far too broad questions. It means different things to different people , especially in different industries. What is your use of each, and someone might provide a good answer.
GIGO.
