Seeking a good silver smith
December 1, 2010
(WORK IN STERLING SILVER HARD)
(REPRODUCED INTO STERLING PIECES)
I AM SEEKING SOMEONE THAT CAN REPRODUCE SOME SMALL METAL OBJECTS SUCH AS 1'' HINGES , SOLID KNOBS 1/2 '', AND LATCHES, AND THE HARD ONE A LATCH THAT CLOSES TO A SOLID 1/2'' KNOB. THE LATCH MIGHT HAVE TO BE TAKEN APART TO DO AS IT LOOKS 3 PIECES MECHANISM.
TOTAL IS ABOUT 12 PIECES, ALL UNDER 1 1/2'' BUT ONE APX. 3'' LONG NARROW AND THIN PIECE.
I WOULD LIKE AN ESTIMATE FROM SOMEONE THAT IS EXPERIENCED IN DOING THIS AND MAKES NICE SOLID STERLING SILVER AND HARD ENOUGH THAT THE MECHANISM WORKS. IT WILL HAVE TO BE A GOOD MIX OF HARD SILVER BUT STILL HAS THE STERLING APPEAL FINISH.
(PURPOSE) FOR A CASE.
MATERIAL IS ( METAL/HARDWARE)
I WOULD LIKE THE OLD PIECES BACK WHEN DONE.
HINGES HAVE TO HAVE A HOLE THRU THEM TO WORK.
( CLOSE ESTIMATE IS OK).
hobbyist - Ocean Park, Washington, USA
