Electropolishing using a welding power supply
December 2, 2010
Hello,
We are going to use SS 304 and a phosphoric/sulfuric/distilled water solution for electropolishing.
1. It is very expensive to get the appropriate power supply here in India, of 12 volts and 300 amps. Because of our limited budget, we want to experiment with a welding power supply. That is however choppy DC current; is that an issue?
2. Will 36 volts and 300 amps be problematic/dangerous? Is there a maximum voltage that can be used in electropolishing?
Rishi Walker
PD - Tamil Nadu, India
