Black Tendrils on Diamond Cut Aluminium Surface
November 25, 2010
I am the QC director for a UK Hi Fi speaker company that prides itself on the quality of its products.
We are developing an new range of products using diecast aluminium with a diamond cut high reflective surface. However we are now seeing black tendrils developing on the surface of diecast aluminium ADC12, after diamond machining and clear lacquering. Has anybody experience of this and how to overcome it?
Quality Control - Rayleigh, Essex, UK
A guess, I would check to see it the cutting fluid was truly compatible with the particular aluminum that you are using.
James Watts- Navarre, Florida
November 26, 2010
Could this be filiform corrosion ? - If it occurs after lacquering.
Richard Guise- United Kingdom
December 3, 2010
I would like to thank both James Watts and Richard Guise for their replies. It does seem to be filiform corrosion. Now we know what it is we can begin to deal with it.
Eric LytraHi Fi - Rayleigh United Kingdom
December 14, 2010
