Brush stainless steel without electric tools
Can I use sandpaper in a circular motion to make a brushed finish on my stainless steel table top? Thanks for any suggestions!
Tool less
student - Minneapolis, Minnesota, USA
November 21, 2010
Hi, Marta.
It totally depends on what you mean by brushed finish and what look would be acceptable to you. Most people mean a unidirectional finish that is actually done with one quick scritch from a very large belt sander. I doubt that you could do it by hand without overlap lines being obvious unless you have the patience of a saint.
But you can certainly, and very easily, put scratches into stainless steel with sandpaper, and overlaps are not necessarily ugly if done with a flair. The beautiful and familiar small circles called a "dowel" or " jeweled" or "machine turned" finish is an example of an overlapped finish (letters 13213 and 26417 illustrate it); and while this is too small and precise to do by hand, some sort of overlapping arcs should be doable if you have talent.
November 24, 2010
