Zinc plated piston compatibility with aluminum body
We are using in the car rear brake assembly aluminum as a w/c material, and for steel piston using Cr3 zinc plating. Will this combination work?
Anup BhawtankarProduct designer - Pune, Maharashtra, India
October 27, 2010
Dear Mr Anup,
What is it that you want to make work in this combination?
Corrosion compatibility - wear resistance - Please post a picture of the assembly if possible to merit a better response?
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
November 24, 2010
Actually in the brake wheel cylinder assembly we are using a pistion with Zinc CR3 plating and its matching bore surface is made up of Aluminum with anodised bore. I want to know whether this combination will work OR not?
Automobile - Pune, Maharashtra, India
December 3, 2010
Dear Mr Anup,
Your designers must have planned a life cycle for this assembly? Normally these pistons are never zinc plated since they are supposed to take wear and tear and zinc is too soft for such a critical application. Electroless Nickel is normally used - if zinc was designed in the first place it may be worthwhile looking at harder deposits such as zinc nickel plating as an option.
Khozem Vahaanwala
Saify Ind
December 4, 2010
