Salt Spray Rating of .6 g/in^2 Zinc Coated Galvaneal
I need to know the salt spray rating of .6 g/in^2 zinc coated galvanneal. I need this information to certify the use of an electrical enclosure in a bottling company environment.
Robert D. Ward
- Advance, Missouri
Maybe you should test some samples in salt spray. If you need information for certification purposes, getting actual test data is preferred over using reference data.
tim neveau
Tim Neveau
Rochester Hills, Michigan
