Pump shaft material for water application
Which is better material for submerged pump shaft. SS 316 or SS 410.
Application is filtered water.
Avinash Ambardekar
engineer - Bangalore, India
October 22, 2010
410 is a lot stronger, but it will rust a lot quicker. If you have a near neutral pH and low chlorides, I would probably use 304 as it will work well and is normally more available and cheaper.
Tungsten Carbide may be the best substitute.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
December 4, 2010
