Plating steel PCB components with "nickel-silver" alloys instead of tin
Steel fences plated with tin are often soldered to printed circuit boards and used in electronics. Tin without lead is prone to growing tin whiskers, so it is best to avoid tin plating. Can steel fences instead be plated with a "nickel-silver" alloy such as alloy C770 or C752 (copper, nickel, zinc alloy)?
Jeff BesethProduct designer - Olathe, Kansas, USA
October 19, 2010
Tin with a trace of bismuth does not have much of a whiskers problem. Nickel silver will cost a lot more and I wonder about its solderability as it ages.
James Watts- Navarre, Florida
October 20, 2010
adv.: Supplier of Copper Anodes, Nickel Anodes, Bismuth Metal, & Other Metal Products for Industry & The Arts
