How to remove carbon or flux after welding?
I did welding at ms wire, but welding carbon spread in the welding joint which affects coating.........give me a solution of it...........thanks a lot
Chuwamaa Mastichooo
production manager - Colombo, Sri Lanka
October 1, 2010
November 10, 2010
HI CHUWAMMA,
YOU CAN USE A SOLUTION WITH;
H2SO4 20%
HCl 20%
INHIBITOR 2%, TIME 10 MIN
FIRST YOU ADD H2SO4 TO WATER THEN HCl ADD TO THEM
THEN ADD INHIBITOR.
GOOD LUCK
ASAD SHAHBAZI
- ARAK, IRAN
