17-4 Stainless Steel Corrosion in a Marine environment
Hi I work for a company that manufactures Survival Capsules for the Offshore Industries.
These Capsules are supported by a Release Mechanism or "Hook". In this particular application, the Hook Nose is manufactured from 17-4 Stainless Steel which rotates around a 17-4 Pin which in turn is supported by a 316 Stainless Steel Housing. The 316 housing remains in a good condition, but after only a week or so, the 17-4 Hook Nose looks "bad". It looks like it has considerable corrosion. I know it's only surface "tarnish", but the customer wants his hook to look "nice & Shiny".
Any thoughts on how I can keep the Hook Nose looking "nice & shiny" would be much appreciated.
Engineer - Vally Center, California, USA
September 28, 2010
Hello, Sid. It's molybdenum in the 316 alloy that is responsible for the extra corrosion protection in marine (chloride) environments. The 17-4 simply lacks that key component. Sorry about that.
Jon Barrows, MSF, EHSSC
Independence, Missouri
September 30, 2010
We can suggest special passivation process. Such passivation creates strong corrosion protection layer on the surface of 17-4 stainless steel (parts look shine and bright). Based on the corrosion tests results the passivated parts can stand such test 3 times longer than non-passivated ones.
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
October 11, 2010
Passivation and alloy choice are both of major importance in marine environments. Even 304 stainless doesn't hold up as well as 316.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
October 21, 2010
