tartaric acid anodising controls
Q. Hi. Setting up anodising line for tartaric, and have been told I need a control and data logging system. Could anyone give help or guideline to this? Will be working to Airbus specs
bill kinsellaplating shop worker - chester UK
September 20, 2010
A. Are you asked to log the temperature, or is it some other control parameter? Temperature logging is actually very straightforward. The old-fashioned way is to use a chart recorder with paper records. I prefer to select a digital temperature controller that has a retransmit signal (4-20 mA or 0-10 VDC). You can pair that with any process data logger to receive that signal. You can get loggers that either store the information in internal memory for manual periodic retrieval and upload to a PC or you can get loggers that wirelessly transmit the signals directly to a remote data collection PC. Good luck.
Jon Barrows, MSF, EHSSC
Independence, Missouri
September 23, 2010
Q. Hi. Where can I get information on tartaric anodise?
Cheers, rod
- wigan england
October 10, 2014
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
(note: this book is two volumes)
AbeBooks
A. Hi Rod. "The Surface Treatment & Finishing of Aluminium and Its Alloys" covers everything related to the anodizing of aluminum, so it's the accepted source for all such info. But I think you need to put your inquiry into context because we don't know if you're interested in the formation process for electrolytic capacitors, or complying with an Airbus spec. for an alternate to chromic acid anodizing, or what. Thanks.
October 2014
Q. Hi ted. Airbus spec. We have not yet put this line in, but will be in the near future.
Regards, rod
- wigan england
October 14, 2014
A. Hi Rod,
Currently, our company has setup the TSAA line as per Airbus requirements for since 2010. Is there any specific info that you are looking too??
Aerospace Manufacturer - Sungai Buloh, Selangor, Malaysia
January 12, 2015
Q. All the info I can get please. Thanks, rod.
rod astle [returning]- wigan england
January 16, 2015
