Chrome plating for long length bar
i am looking for a chrome plating for long length bar with the thickness of 0.055 to 0.077 µm . on H13 Hot die steel material.For such application I am looking on line method of doing . Can you suggest the machine dealer or Machine suppliers details world wide ,
Kind Regards
sachin
Mandrel bars - Gujarat - India
September 18, 2010
Hi, Sachin.
When you have a terrible stitch in your right side, you look for a surgeon, not a scalpel supplier :-) While it is certainly possible for you to do hard chrome plating in house, if that's what you really want -- just in case you didn't know it, chrome plating is a complicated business and there are shops that offer the service. The usual way of dealing with your situation would be to find a plating shop rather than a chrome plating equipment supplier. Good luck.
September 21, 2010
Hallo Sachin, Hallo Ted
"Through Feed Plating" is the easiest method for chrome plating long bars.
Using this plating equipment you can obtain what you need with a very small quantity of plating solution and the process is completely safe.
I will suggest to you to check online , you will found very interesting information.
- Milan, Italy
October 1, 2010
