Zinc Plating is Cracking
We apply a layer of electroplated zinc (about 10-15 microns thick) on zinc-aluminium castings. Once the items are working (automotive structural parts) sometimes transversal cracks are observed through the layer (no corrosion evidence at all). Could they come out from wrong electroplating parameters (temperature, chemistry) causing tensile residual stresses inside the coating?
R&D - Carpi, Italy
September 15, 2010
Hi,
What is the chemistry of the zinc plating process? Acid base can cause more internal stress in the layer than the alkaline base process.
Saludos
Jobshop - SLP, Mexico
September 28, 2010
Hi,
WHAT TYPE OF PASSIVATION IS ON YOUR ZINC PLATING? WHAT IS THE TEMPERATURE OF DRYING? LOWER THE TEMPERATURE OF DRYING. HIGH TEMPERATURE WILL CRACK THE CONVERSION COATING BY DEHYDRATION.
- KOLKATA
October 9, 2010
