Thread 557/01
Zinc thickness of different galvanization processes
What is coating thickness (in Microns) of Zinc in Pre Galvanized and Electrogalvanised Material after completing the Product? For Hot Dip Galvanized ,I believe the Thickness is min 55 Microns and Average is 80 Microns and For Corten A Materials the thickness would be 185 Microns Min. Am I right. Can you reply?
JIBIN PAULSales Engineer - Doha ,Qatar
September 9, 2010
publicly reply to JIBIN PAUL
Sir
Hot Dip Galvanizing if you will follow british standard the thickness will vary from material to another such as if a big parts the thickness ( 80 to 120 microns) , for nails (40 to 45 microns), for sheets ( 15 till 35 microns)
Best Regards
Yasser Alshafee
Senior Chemist
steel factory - - Cairo, Egypt
September 19, 2010
publicly reply to Yasser Alshafee
