301 SS Passivated incorrectly
A subcontractor passivated 301 stainless steel parts using AMSQQP35 [canceled] Type VIII instead of Type VI or VII. The parts showed rust in the bend radius, indicating ineffective cleaning and passivation, where I would expect it. 1. I've always have had an issue with the copper sulphate on eBay or Amazon [affil links] test, since typically, the copper sulphate solution is only applied to a small spot, likely a "flat" surface, and least likely to be an area with smeared iron. 2. Most importantly, I haven't a readily available published resource. Is there likely to be metallurgical attack of the 301 from Type VIII time-temperature-chemistry?
Douglas Hahn
process engineer - Saint Charles, ILLINOIS
September 8, 2010
